Author Topic: DOORS Add-in  (Read 5308 times)
MarcinG
DOORS Add-in
« on: March 16, 2023, 12:55:05 am »
was anyone successful installing 16.1 and adding a DOORS add-in to it (3.0.301.4) ?   It does nto show up on the list of technologies after installation, and trying to add it manually results in nothing - no error, no message ...
Best regards
Marcin
Re: DOORS Add-in
« Reply #1 on: March 16, 2023, 02:05:05 am »
Did you install the 64 bit edition of EA and the 32 bit edition of DOORS?
If that is the case, then that is to be expected.
Make sure you install the same bitness of add-in and EA.
Re: DOORS Add-in
« Reply #2 on: March 16, 2023, 07:56:58 am »
For the DOORS add-in you need the 32 bit version of EA.
MarcinG
Re: DOORS Add-in
« Reply #3 on: March 16, 2023, 09:45:48 pm »
Yes, the EA is in 32 bit version.  Same error on few machines, got a bug solution suggestion from Sparx, but it is not that easy to try.  It requires editing registry settings, and that's a no-no in my organization.  Registry editing blocked, so need to wait for IT admins to help.  Then we will see if it works.
