Author Topic: SQL Search on tag value - how to?  (Read 3899 times)
Ribeye
« on: March 20, 2023, 03:42:28 am »
We need to find elements in our model by the value of Tags. Foreign keys to external systems, for example.
This seems like a common requirement and we are new to EA SQL.
Can someone point to or provide a snippet of SQL that will do this?
Thanks in advance.
Re: SQL Search on tag value - how to?
« Reply #1 on: March 20, 2023, 04:47:15 am »
Try
SELECT * FROM t_objectproperties WHERE object_id = <the element id>
Depending on the mix of MDGs you are using you might need additional info from t_xref, but give the above a try first.
