Author Topic: Create ArchiMate 2 element through script  (Read 4596 times)
Filip Hendrickx
« on: June 20, 2013, 11:46:01 pm »
Hi all.
I try to create ArchiMate 2 elements through a vbscript, like this:
dim elements as EA.Collection
set elements = currentPackage.Elements
elements.AddNew("elementName", "ArchiMate2::SystemSoftware")
This example seems to work fine. However when using "ArchiMate2::Device" it creates an ArchiMate 1 Device, and when using "ArchiMate2::ApplicationComponent" I get a TOGAF ApplicationComponent.
I would expect that I should use the exact type names from the technology definition ("ArchiMate2::ArchiMate_SystemSoftware" etc. like in the Scripting EA book) but this gives an error message (wrong type).
While there are workarounds, I was wondering if anyone could point out the correct way of creating these ArchiMate2 elements.
Best regards,
Filip.
Dermot
Re: Create ArchiMate 2 element through script
« Reply #1 on: June 21, 2013, 02:49:44 pm »
Have you tried disabling Archimate 1 in the: Settings |  MDG Techologies.
Filip Hendrickx
« Reply #2 on: June 21, 2013, 03:47:20 pm »
Hi Dermot.
That seems to work, nice trick!
(Still a workaround, though, so if anyone knows another way around this, I'm curious.)
Thanks very much,
Filip.
« Reply #3 on: June 21, 2013, 07:27:11 pm »
Filip,
It's not really a workaround. You have to choose between archimate versions. Both can't be active at the same time because of various conflicts.
mlk
« Reply #4 on: June 23, 2013, 06:29:35 pm »
Try this:
Element newElement = package.Elements.AddNew("Example_dev1", "Class");
newElement.Stereotype = "ArchiMate_Device";
newElement.Update();
