Author Topic: Time trigger and After(time)  (Read 3846 times)
Wishmaster84
« on: April 05, 2023, 05:46:16 pm »
Hi All,
I need to create a time trigger that perform a transition after a period of time. I would like to use the after(time) trigger. Is it supported by EA?
Re: Time trigger and After(time)
« Reply #1 on: April 05, 2023, 09:18:09 pm »
In the State toolbox under Additional you find a Trigger element. Drag that onto the diagram and in the Properties under Trigger change Type to Time.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: April 06, 2023, 09:42:31 am »
Hello Wishmaster84,
How to create a Trigger is as qwerty wrote, but I guess that you want to use the 'after' trigger in the EA simulation feature. (The 'after' trigger has a special meaning, defined in the UML specification.)
If so, unfortunately the simulation feature for Statemachines does not support the 'after' trigger. You need to fire the trigger manually during simulation.
t-kouno
