Author Topic: "Bad object type" Error when trying to import new requirements.  (Read 11827 times)
e2e-RHormbrey
Hi All
I am having an issue with importing requirements into an EA cloud repository from a csv file. I get the following error:
Bad object type or Profile Metatype when creating new record of type ''
Searching these forums and google, the only suggestion I found was that I need to include the Type field and ensure each one has the type "requirement". However I have done this and still get the Error.
It appears to be an issue with the specific repository (I am working on a cloud repository), I tried creating a new local repository and importing into that works as expected with the same csv files / import specification.
Re: "Bad object type" Error when trying to import new requirements.
« Reply #1 on: April 27, 2023, 07:22:58 pm »
Have you tried connecting to your repository though a direct database connection instead of though the Procloud server?
That might make a difference
BobM
« Reply #2 on: April 27, 2023, 09:39:31 pm »
I think it indicates there is a type <blank>
Do you have as ,any fields in your csv as you have specified in the import?
For a requirements example I once imported I used the headers as well
