Author Topic: Query works in 16.0 but stops working 16.1  (Read 12216 times)
nilspc
« on: May 09, 2023, 08:51:27 pm »
Upgraded to v16.1 and discovered that one of our queries no longer work
this query works in 16.0
select f.ea_guid,c.ea_guid,f.name, c.name
from t_xref as a, t_connector as b, t_object as c,  t_object as f,  t_objectproperties as tag2
where a.behavior = 'conveyed'
and a.Description LIKE '%'+c.ea_guid+'%'
and a.client = b.ea_guid
and b.Start_Object_ID = f.Object_ID
and f.Object_ID = tag2.Object_ID and tag2.Property = 'ID'
By working I mean that it returns values in all 4 columns.
In 16.1 column 1 and 3 are blank.
I discovered the problem when running one of our script but the query builder have the same behavior.
And the problem occurs both in a repository in an sqlserver or a local qeax file
Anyone seen something like this? is the something I am missing?
Regards
Nils
Re: Query works in 16.0 but stops working 16.1
« Reply #1 on: May 09, 2023, 09:05:23 pm »
You have name and ea_guid twice. Use an alias for the second Name
I would also suggest to rewrite your queries using the proper join syntax and use meaningful aliases for your tables.
That makes reading (and editing) queries that much easier.
select f.ea_guid as StartGUID ,o.ea_guid as ConveyedGUID, f.name as StartObject, o.name as ConveyedObject
from  ((((t_connector  c
inner join t_xref x on (x.client = c.ea_guid
and x.behavior = 'conveyed'))
inner join t_object o on x.Description LIKE '%'+o.ea_guid+'%')
inner join t_object  f on c.Start_Object_ID = f.Object_ID)
left join t_objectproperties tv on (f.Object_ID = tv.Object_ID
and tv.Property = 'ID'))
nilspc
« Reply #2 on: May 09, 2023, 09:20:00 pm »
Thank you for a very quick response
Upgraded to 16.1 again and it now works  :D
Strange though that it worked in 15.2 and 16.0
Regards
Nils
« Reply #3 on: May 10, 2023, 08:12:18 am »
The problem is that you also changed either the database or the connection method. The "native" connections and .qea files both work with a different database layer.
