Author Topic: Create a composite diagram  (Read 6526 times)
Pedro
« on: June 25, 2013, 12:41:30 am »
I have the following code, which works creating a diagram:
 private static void CreateDiagram(string _name, Package _root)
            var tmp = (Diagram)null;
            try
                tmp = _root.Diagrams.GetByName(_name);
            catch
            if (tmp == null)
                tmp = _root.Diagrams.AddNew(_name, "Component");
                tmp.HighlightImports = false;
                tmp.Update();
                _root.Diagrams.Refresh();
                _root.Update();
            ///The diagram already exists, and we do not create it. (Empty else)
HOW can I make it composite? Please, this is extreme easy in the in EA but looks impossible for me in my addin code.
Re: Create a composite diagram
« Reply #1 on: June 25, 2013, 03:34:39 pm »
There are a few post from a long time ago that explain how to do it.
Use the top left search button and search for "composite".
Aaron B
« Reply #2 on: June 26, 2013, 09:48:44 am »
See IsComposite on the Element Class:
http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/element2.html
If your element already contains a diagram, setting IsComposite = true will link to the existing sub diagram.
You code sample seems to be adding a diagram to a Package though - you do not need to set a Package as Composite.  Double-clicking on a Package within a diagram should automatically open it's sub diagram anyway.
« Reply #3 on: June 26, 2013, 06:37:13 pm »
Aaron,
IsComposite is documented as being read-only  :-/
Is the documentation wrong?
Aaron B
« Reply #4 on: June 27, 2013, 11:24:07 am »
IsComposite is Read/Write.  Maybe you are getting confused with CompositeDiagram, which is read only.
« Reply #5 on: June 27, 2013, 03:50:27 pm »
True, by [highlight]my[/highlight] bad :-[
« Last Edit: June 27, 2013, 04:43:56 pm by Geert.Bellekens »
RoyC
  • Read The Help!
« Reply #6 on: June 27, 2013, 04:37:47 pm »
True, by bad
These computer people who work too intently on their programs - they are always getting a code in the nose...
Best Regards, Roy
« Reply #7 on: June 28, 2013, 12:13:09 am »
Gesundheit!
