Author Topic: SQL "like" operator not working in script  (Read 3929 times)
SevEd
« on: May 17, 2023, 06:14:14 pm »
Hello everyone,
I'm having issues when running a SQL query in one of my scripts. The issue is when using the "LIKE" operator. See below a snippet of the code (VBScript):
    looksimilar = eaElement.Name & "#WC#"
    query = "SELECT t_object.ea_guid " & _
            "FROM t_object " & _
            "WHERE " & _
                    "t_object.Object_Type = " & Chr(34) & "UseCase" & Chr(34) & " AND " & _
                    "t_object.Stereotype = " & Chr(34) & "Dynamic Architecture" & Chr(34) & " AND " & _
                    "t_object.Name LIKE " & Chr(34) & looksimilar & Chr(34)
    dbgPrint("query")
    dbgPrint(query)
    xmlResult = Repository.SQLQuery(query)
    dbgPrint("xmlResult")
    dbgPrint(xmlResult)
Do you know if there is a bug in the SQL API? or is this operator not supported in the scripts?
using as example:
looksimilar = "APPSWC_Voltage_Monitoring#WC#"
The output query is:
SELECT t_object.ea_guid FROM t_object WHERE t_object.Object_Type = "UseCase" AND t_object.Stereotype = "Dynamic Architecture" AND t_object.Name Like "APPSWC_Voltage_Monitoring#WC#"
In the script the xml output is empty. But if I run the query in the Query Builder, the output is as expected. Do you know what I am missing here? Any recommendation?
Thanks for your help!
Best regards,
Edgar Sevilla
Re: SQL "like" operator not working in script
« Reply #1 on: May 17, 2023, 06:36:14 pm »
Hi Edga,
Macros's such as #WC# are only evaluated when going through the GUI, not via the API.
So you'll have to replicate them yourself. If you are using a .eap file that's "*", else it's "%"
on another note, the text indicator in SQL is a single quote, so you can write something like
"t_object.Stereotype = 'Dynamic Architecture' AND " & _instead of
Much easier to read and write I think.
If you are dealing with a lot of queries in VBScript, you might appreciate this little tool I made: https://github.com/GeertBellekens/TextHelper/releases (it's also included in EA-Matic)
It will transform queries like this:
select o.Object_ID from t_object o
where o.Name is not null
and o.Package_ID in (" & packageTreeIDs & ")
and not exists (
select * from t_diagramobjects do
where do.Object_ID = o.Object_ID
and do.Diagram_ID = " & diagram.DiagramID & "
Into
"select o.Object_ID from t_object o                 " & vbNewLine & _
" where o.Name is not null                          " & vbNewLine & _
" and o.Package_ID in (" & packageTreeIDs & ")      " & vbNewLine & _
" and not exists (                                  " & vbNewLine & _
" select * from t_diagramobjects do               " & vbNewLine & _
" where do.Object_ID = o.Object_ID                " & vbNewLine & _
" and do.Diagram_ID = " & diagram.DiagramID & "   " & vbNewLine & _
And vice versa
SevEd
« Reply #2 on: May 17, 2023, 07:02:19 pm »
Hi Geert,
Thanks for you quick response. It's working correct after the fix using "*" instead of "#WC#"
Also, I also find your suggestion really useful for improving readability!
Thanks again for your support
Best regards
Edgar Sevilla
