Author Topic: (Simple) diagram report  (Read 4272 times)
Modesto Vega
« on: May 22, 2023, 10:20:07 pm »
In previous version of Sparx EA it used to be possible to create a (simple) diagram report using the out-of-the-box Diagram Report document template, from memory it used to work to usable degree. In version 16, the "same" document template produces an empty document. Has anything changed? Is this functionality now broken?
Modesto Vega
Re: (Simple) diagram report
« Reply #1 on: May 23, 2023, 10:37:43 pm »
Just a quick update on this, the behaviour described in the OP only happens when attempting to generate a diagram report from within a diagram. Diagram reports are generated as expected if run from the package containing the diagram. If the package contains multiple diagrams, most packages do, all diagrams in the package are included in the document, instead of just one.
I am still unclear if this a bug/issue, a change of functionality or something that was always there.
