Author Topic: Script to generate requirements from actors and acitvities  (Read 6671 times)
Hurra
    • Find me at LinkedIn!
Hello!
I use NAFv4 and have modelled Operational Views with the following:
«OperationalPerformer» --- IsCapableToPerform --> «OperationalActivity»
From this I create stakeholder requirements with the following syntax:
The system shall enable «OperationalPerformer» to «OperationalActivity».
I know seems like a waste, but it's a government agency 😇 "it has to be textual requirements"
🤔I just wanted to know if someone have any ideas of how I can keep track of which performers and acitvities which have requirements. My thought is to be able to generate these requirements when there are changes in the Operational Views. E.g. a new performer, or added activities to an existing performer.
💡One idea that pops up is to create a connector (maybe «trace»?) between the requirement to the performer and activity. And before creating a requirement, check if there is a corresponding requirement for the performer and activity in focus. If there is a requirement, just update the requirement text.
❓Any thoughts of how I can implement such a thing, and is the connector approach any good? Is there another way?
Thank you!
always learning!
Sunshine
  • Its the results that count
Re: Script to generate requirements from actors and acitvities
« Reply #1 on: May 23, 2023, 05:22:52 pm »
Govt Agency - you and me both.
You could you a matrix of performers vs activities.
You could also baseline and compare to see any differences periodically.
mmh? that sounds like extra work and in a large project likely to become unsustainable.
Rather than create a requirement element why not just generate the requirement via document generation. You've already modelled «OperationalPerformer» --- IsCapableToPerform --> «OperationalActivity»
so it shouldn't be too hard to create a MS Word document that transposes that into
You may need to create a document fragment to achieve that with some SQL behind the scenes.
Interesting to see NAFv4 https://www.nato.int/cps/en/natohq/topics_157575.htm Looking at those documents I see they are using Sparx Enterprise Architect.  :)
Happy to help
Hurra
« Reply #2 on: November 09, 2023, 12:24:52 am »
Well, we need a status of the requirement, approved/implemented/verified/validated etc and also an ID. Therefore I don't think it's enough to only generate the requirement in the document. With a seperate object for the specific requirement based on OperationalPerformer and OperationalActivity we can do that easily.
I don't see we can do that with only generating text in the document. How would we keep track of status and ID?
What I do atm is to wait with generating the requirements as long as possible, then handle the changes and new stuff manually.
Thanks for your input.
always learning!
