Author Topic: Mapping of SysML Stereotypes to UML Metclasses  (Read 7106 times)
wikitect
    • TRAK Community
« on: June 08, 2023, 07:42:32 pm »
https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_frameworks/create_toolbox_profiles_using_.html
In order to create a Toolbox Palette element (extending a ToolboxPage) the base metaclass needs to be correct. Sometimes there are slight variations in the name of the metclass used to toolbox elements vs that of the 'vanilla' UML metaclass element.
SysML doesn't have its own metaclasses only Stereotypes so somehow the user has to establish what base  UML Metaclass has been extended by the SysML element to be used for the toolbox element - https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_frameworks/non-uml_metatypes.html
There is a list of the UML Metclass names to be used for UML elements - https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_frameworks/elements_used_in_toolboxes.html
Is there a similar mapping between SysML elements and UML Metaclasses? How is it possible to establish this? Surely I don't have to try and piece this together using the normative SysML profile from the OMG and keep my fingers crossed that the same names apply?
Favourite epitaph: 'Under this sod lies another'
TRAK Framework https://sf.net/p/trak
MDG for TRAK https://sf.net/p/mdgfortrak
Re: Mapping of SysML Stereotypes to UML Metclasses
« Reply #1 on: June 08, 2023, 08:02:26 pm »
The real info is stored in the SysML MDG file, but this query could also help
select distinct o.Object_Type, o.Stereotype
  from t_object o
 inner join t_xref x on x.Client = o.ea_guid
and x.Name = 'Stereotypes'
and x.Description like '%FQName=SysML1.4%'
wikitect
    • TRAK Community
« Reply #2 on: June 09, 2023, 12:15:19 am »
Thanks Geert - a lot more help that a reference to interrogating some weird API.
BTW where are the built-in MDGs kept? Might be worth me pointing my XML development tool at it to see what I can find ....
« Reply #3 on: June 09, 2023, 12:31:26 am »
Some of them are in %program files%\Sparx Systems\EA\MDGTechnologies and those you can actually read.
Some others are in  %program files%\Sparx Systems\EAInternalTechnologies . These are actually somehow binary encoded, and I haven't found a way to read them (yet)
SysML is in the latter case.
wikitect
    • TRAK Community
« Reply #4 on: June 09, 2023, 12:35:22 am »
Tried to do the same for connector elements using t_connector, Connector_Type , Type = 'connector property' but not working yet.
« Reply #5 on: June 09, 2023, 01:50:46 am »
This should give you the same for connectors:
select distinct c.Connector_Type, c.Stereotype
  from t_connector c
 inner join t_xref x on x.Client = c.ea_guid
wikitect
    • TRAK Community
« Reply #6 on: June 09, 2023, 10:36:37 pm »
I'm missing SysML stereotypes in the list returned from the query vs what is offered by the Extend Metaclass dialogue > Stereotypes > SysML1.4
Missing in terms of Requirement are the following relationships:-
  • SysML::deriveReqt
  • SysML::satisfy
  • SysML::verify
[li\SysML::conform[/li]
[/list]
« Reply #7 on: June 09, 2023, 11:04:58 pm »
    • SysML::deriveReqt
    • SysML::satisfy
    • SysML::verify
    [/list]
    The query can only return those that are actually used in this model.
    So if you haven't used them they will not show up. If I run that query on my model it returns nothing at all (since I don't use SysML)
    wikitect
      • TRAK Community
    « Reply #8 on: June 09, 2023, 11:42:32 pm »
    Understood. It's certainly causing me a lot of grief adding the SysML profile(s) so tomorrow morning there's going to be a long email to Sparx Support ....
    « Reply #9 on: June 10, 2023, 12:19:57 am »
    Another technique is to create the correct thing, and then remove the stereotype. That leaves you with the plain UML typed object.
    That is what I usually do when doing profiles
    wikitect
      • TRAK Community
    « Reply #10 on: June 10, 2023, 09:41:49 pm »
    Thanks. Had forgotten that one. Struggling with SysML::trace which has a UML::Trace base (Toolbox uses TraceLink which creates a EAUML::trace not the SysML one defined).
    « Reply #11 on: June 12, 2023, 04:15:46 pm »
    Trace is a bit of a weird one as it is defined in EA as an abstraction (or sometimes a dependency) with stereotype «trace», so there's no "trace" connector type.
    In terms of toolbox, I think you can go straight to the actual connectortype
    So SysML1.4::trace(UML::Abstraction)
    Could also be a dependency though, check the database to be sure.
    wikitect
      • TRAK Community
    « Reply #12 on: June 12, 2023, 07:03:06 pm »
    I've been around the (trace!) loop in the past - I use the Abstraction for TRAK::traces to  - connector.
    A SysML::trace isn't a UML::Abstraction - it appears to be a UML::Trace.
    Unfortunately toolbox definition does not allow UML::Trace - it only provides EAUML::TraceLink which and therefore you don't end up with a SysML::Trace element which is needed to get the behaviour on a SysML Block compartment visibility for the 'tracedTo', 'tracedFrom' compartments - https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_domains/block_element_compartments.html
