Author Topic: Disallow creation of element with same name  (Read 4048 times)
Mats Gejnevall
« on: June 15, 2023, 06:47:44 pm »
We would like to get a warning whenever someone tries to create a new element of the same type and name as an existing element. Is there a way of doing this or does someone have a solution for dealing with this. The same really applies to relations, i.e. when you create a relation of the same type between two elements.
Mats
Re: Disallow creation of element with same name
« Reply #2 on: June 15, 2023, 09:15:42 pm »
Mats
Mats, to do this properly is more complicated (which is probably why Geert had to script it).
What you are talking about is Namespace definition.
There are two basic dimensions:
Scope
Metatypes
Scope includes Repository-wide, Root-wide, branch-wide, Folder-wide etc.
Metatypes includes All Metatypes, Specific Metatypes etc.
Our repositories have many items with the same name, sometimes in the same folder.  In some folders, we allow multiple items with the same name so long as they are of different metatypes.  Occasionally we even allow multiple items with the same name and the same metatype.
So, simply disallowing duplicates would not be suitable.  However, it would be really cool if Sparx implemented a robust namespace management mechanism.
Modesto Vega
« Reply #3 on: June 15, 2023, 10:21:41 pm »
Mats
Scope
Metatypes
Could not have word it better? Simply disallowing duplicates may not suitable or a good idea. We also have many duplicates in our repository, even of the same metatype, representing different things.
[SNIP]
Seconded, I will even add that they should introduce a Folder element to encourage users to stop using packages as folders, when they are not.
« Reply #4 on: June 15, 2023, 11:51:52 pm »
[SNIP]
Indeed, we have stereotyped most "packages" as "folders" and we have also created special folder elements to allow correct nesting (such as tables in schemas etc.).  We do NOT encourage the export/import of non "package" stereotyped packages.
