Author Topic: Using VBScript to import Excel Files and generate diagrams automatically  (Read 29255 times)
Andre_b_b
Nice. Thanks Geert. Should i get the element by GUID? If yes, i am trying to use the code, but it says that there is a "Internal Application Error".
' Active Diagram
Set Diagram = Repository.GetCurrentDiagram()
' Get 2 elements from their GUID
Set Element1 = Repository.GetElementByGuid("{53C6DD5C-04D6-4b6f-9102-142557A3F4C7}")
Set Element2 = Repository.GetElementByGuid("{49602501-62AA-4426-A862-45B066F62DF0}")
On what line exactly does it give you this error?
Are you sure this guid exists in t_object.ea_guid?
Andre_b_b
There is this "internal error" in the line "Set Element1 = Repository.GetElementByGuid("{53C6DD5C-04D6-4b6f-9102-142557A3F4C7}")". And the GUID i have copied by right-clicking in the element from the browser and copying the GUID. Here it is the code i have been working with. I am sorry, i do not understand what is the t_object.ea_guid you asked me.
option explicit
!INC Local Scripts.EAConstants-VBScript
sub main
Dim Repository
Dim Diagram
Dim Element1
Dim Element2
Dim Connector
Set Repository = CreateObject("EA.Repository")
Set Connector = Element1.Connectors.AddNew("", "Association")
Connector.SupplierID = Element2.ElementID
Diagram.DiagramLinks.Refresh()
Diagram.Update()
end sub
main
Loose the Set Repository = CreateObject("EA.Repository") that creates a new instance of EA (but without a model loaded), which you probably don't want.
The Repository object is a inserted as a global variable in your scripting environment, you can use it without setting it first.
You also don't need the diagram to create an association, and you should only Refresh/Update if really needed.
And you forgot to update() your new connector. Update() means: Save my changes to the database.
Andre_b_b
Thanks for your help Geert.
Unfortunately, even with the suggestions and corrections you've made, i am still not able to run the script and so, i cannot make the connections. The error given is "this object does not manage" and it does reference to the line of "Element1 = Repository.GetElementByGUID("{53C6DD5C-04D6-4b6f-9102-142557A3F4C7}")"
option explicit
sub main
Dim Element1
Dim Element2
Dim Connector
Element2 = Repository.GetElementByGUID("{49602501-62AA-4426-A862-45B066F62DF0}")
   Msgbox ("!")
Connector.SupplierID = Element2.ElementGUID
Connector.Update()
end sub
main
Andre_b_b
I have managed to create the connection, but how can i turn it visible? I would like to show the relation in a diagram.
Hi Andre,
I think you might want to follow a few tutorials to get the basics right.
When setting an object to a variable in VBScript you should use set
You got it right at first, and then you changed it for some reason
this Element1 = Repository.GetElementByGUID("{53C6DD5C-04D6-4b6f-9102-142557A3F4C7}") should be set Element1 = Repository.GetElementByGUID("{53C6DD5C-04D6-4b6f-9102-142557A3F4C7}")
And the supplierID is a long, so it will give you an error when you set a string value (GUID) to it.
I can't keep debugging your scripts for you like this.
Checkout https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library There are lots of scripts that you can use as an example there.
This was suggested in the very beginning. Doesn't look to have been a fruitful suggestion.
Andre_b_b
Thanks guys! I have tried reading the tutorials and everything but i do not understand the documentation, and everything looks advanced to me, so in this moment i am not able to learn - apparently -, that is why i keep asking here in the forum, because i do not find answers in any other place. Sorry for the mistakes and thanks for your help.
You know that people like you are called vampires? I'm pretty allergic against those since I had unpleasant experiences in the past.
Andre_b_b
Excuse me, i am not sure what you mean from this comment. I hope you are not judging me for trying to learn programming and how to use Enterprise Architect.
Don't worry about it too much. Q can get a bit grumpy sometimes ;D
What he means I think is that you might want to do a bit more research/trying yourself before asking for help.
If we look back at the history of this post, you might have called for help too soon a few times, which can be perceived as a send me teh codez request.
For context about help vampires: https://meta.stackoverflow.com/questions/258206/what-is-a-help-vampire
Andre_b_b
ok  :D. Yes, looking back in the post, it really seems i am a "vampire", but if i am, it was not my intention. Sorry guys, i am trying to understand stuff, but sometimes my low-konwledge of programming, in general, do not allow me to evolute  :-\ :-\
