Author Topic: XMI Export fails with "Encountered an improper argument"  (Read 11741 times)
Milan
« on: June 20, 2023, 01:42:22 am »
I encountered an issue with the XMI export in version 16.0.1604 of EA. Whenever I try to export a package of the model I am working on to XMI it fails with the message "Encountered an improper argument". This will hang the EA and I need to restart via task manager. It does not matter which version of XMI I choose nor does it matter what features I select. Additionally, no log file seems to be created even though I selected the option.
This behavior seems to be model dependent. In some other models I am working on it does work as expected. Unfortunately I have no idea what to look for in order to isolate the problem.
Do you have any hints on how to narrow the problem down? Or is this a know issue with version 16.0.1604? Please help.
Best regards, Milan
wivel
  • Driven by Models
Re: XMI Export fails with "Encountered an improper argument"
« Reply #1 on: June 20, 2023, 01:51:01 am »
Hi Milan
Have you tried to run an integrity check on the models in question? (Integrity -> Project Integrity). Remember to check all boxes before running it.
Henrik
Milan
« Reply #2 on: June 22, 2023, 07:31:54 pm »
Hi Henrik,
done that. Result is: No problems found. But it was worth a try. Didn't know this one yet.
Milan
« Reply #3 on: June 22, 2023, 08:39:10 pm »
Since it's V16: report a bug.
wivel
  • Driven by Models
« Reply #4 on: June 22, 2023, 09:45:52 pm »
As he says. So far EA 16.x have not been the best release from Sparx.
It was worth a shot, though. It has helped me when I had strange issues.
Henrik
Modesto Vega
« Reply #5 on: June 22, 2023, 10:23:11 pm »
Assuming that you are using Publish>Export>Export with Full Round trip>XMI Format, this is not an issue in version 16.1.1621. I have successfully exported the Example Model to an XMI file.
