Author Topic: Connection to EA model file via jenkins Job  (Read 3887 times)
umairjadoon
« on: July 06, 2023, 06:46:10 pm »
Hello all,
I am pretty new to EA automation and having trouble running a jenkins job which executes a python script that connects to ea model file. Script runs fine when executed locally on the jenkins node but throw the following error when executed via jenkins.
Traceback (most recent call last):
  File "myscript.py", line 28, in <module>
    ea_repository.OpenFile2("path_to_ea_file.qea", args.ea_user, "")
  File "<COMObject <unknown>>", line 2, in OpenFile2
pywintypes.com_error: (-2147023170, 'The remote procedure call failed.', None, None)
Folllowing is relevant part of the script:
import win32com.client
try:
  eaApp =win32com.client.Dispatch("EA.App")
except:
  sys.stderr.write( "Unable to connect to EA\n" )
  exit()
ea_repository = eaApp.Repository
I assume its more of a Jenkins issue then EA but i couldnt find any thing that helped me so far. Thanks in advance
Re: Connection to EA model file via jenkins Job
« Reply #1 on: July 06, 2023, 07:30:10 pm »
EA is a client application that will only run in a user context, of a user that has a license for EA.
umairjadoon
« Reply #2 on: July 06, 2023, 08:10:01 pm »
Hi Geert,
Thanks for the reply. We are using the floating license from a shared key store. EA runs fine when i login with the same user that runs the Jenkins job. so this rules out the context issue or i am misunderstanding something here?
« Reply #3 on: July 06, 2023, 08:15:41 pm »
Hi Geert,
Looks like it, unfortunately I don't have any experience with Jenkins, so I can't confirm.
I've seen some posts about Jenkins on the this forum, so it might be worth to do a search.
