Author Topic: Updating a matrix specification  (Read 24002 times)
Modesto Vega
« on: July 07, 2023, 02:43:11 am »
I have a matrix specification in a diagram and save it as a matrix profile. Later on I realised that I wanted to switch the source and target around. I used the matrix specification to switch them around and also updated the matrix profile.
The matrix profile, loaded from resources tab of the browser, looks fine - i.e., has the source and target switched around. However, the matrix specification in the diagram still shows the original source and target arrangement - i.e., before switching them around.
What have I missed?
P.S.: Using v16 (Build 1621), 64-bit and ProCloud Server.
Marc Lampron
Re: Updating a matrix specification
« Reply #1 on: September 06, 2024, 01:31:53 am »
Hi,[/color] I have the same problem here. [/size] It seams to me that saving matrix profile has never work correctly. Everything is fine as long as you are in the matrix view, and you change parameters. After you set all parameters the way you want them and you go to the “Option” button, then you ask to “update the profile” or “save as new profile”. It looks like it does what expected but nothing get saved.
Marc Lampron
« Reply #2 on: September 06, 2024, 02:19:12 am »
Regarding the problem I described in my previous message, my context could be different then yours. I am using the French version of EA v16 (the same problem existed in previous versions: v12, v13, v14, v15) and when I try to update a matrix profile, I get the following error message:
Pro Cloud Server: Query in batch execute failed with message: FAIL: Microsoft OLE DB Provider for SQL Server [-2147217900] Syntaxe incorrecte vers 'Information'. in the System Output window.
Something is lost in the translation  :-\
Marc Lampron
« Reply #3 on: September 06, 2024, 04:10:32 am »
I thing I should report this bug about matrix profiles not updating in the french version of EA (at least)
