Author Topic: Connector.StyleEx - LinkedToElementFeature  (Read 5886 times)
David Rains (bioform)
« on: July 11, 2013, 05:24:37 am »
Doing some work prototyping a solution to derive connector tagged values based on what element feature (operation or attribute) the connector is linked too... PART of my effort to implement SBV within requirement engineering using EA...
t_connector.StyleEx seems to use LFEP/LSEP prefixes regardless if it is an operation or an attribute.
vbScript function - to extract GUID of LinkedToElementFeature
public function IsConnector_LinkedToFeature( byval styleEx_Value, byval connectorEnd2Check, byref targetFeaturedGUID )
      'Example: Links to Attributes
      ' LFEP={B7306EA4-E8F3-4743-80EE-BDF36534E1AF}L;LFSP={0C85C78D-9173-4cf4-A2C2-85BE7C8FB7B4}R;
      'Note: Prefix LFEP/LFSP are the same regardless of link to feature's attribute or operation
      dim strTargetPrefix, iStartPosOfGUID
      dim blnResult
      blnResult = False
      if len( styleEx_Value ) > 0 then
            select case lcase(connectorEnd2Check)
                  case gcStrTARGET_END
                        strTargetPrefix = "LFEP="
                  case gcStrSOURCE_END
                        strTargetPrefix = "LFSP="
                  case else
                        msgbox "reClassLibrary.IsConnector_LinkedToFeature - Expected value of 'target' or 'source'"
            end select
            'Search for start of Target GUID
            iStartPosOfGUID = instr( styleEx_Value, strTargetPrefix )
            if iStartPosOfGUID > 0 then
                  blnResult = True
                  targetFeaturedGUID  = mid( styleEx_Value, iStartPosOfGUID + len( strTargetPrefix ), gcEA_GUID_LENGTH )
            end if
      end if
      IsConnector_LinkedToFeature= blnResult
end function
ANYONE interesting in SBV & SBVR give me a holler!  :)
Re: Connector.StyleEx - LinkedToElementFeature
« Reply #1 on: July 11, 2013, 04:13:24 pm »
Cool, I've been working on these linkedfeature stuff as well recently in order to make them available in the EA Navigator.
Here the important part in my code ConnectorWrapper.cs
   private UML.UMLItem getLinkedFeature(bool start)
          string styleEx = this.wrappedConnector.StyleEx;
          string key;
          UML.UMLItem linkedFeature = null;
               if (start)
                key = "LFSP=";
               }else
                     key = "LFEP=";
               int guidStart = styleEx.IndexOf(key) + key.Length ;
               if (guidStart >= key.Length)
                string featureGUID = styleEx.Substring(guidStart,this.WrappedConnector.ConnectorGUID.Length);
                linkedFeature = this.model.getItemFromGUID(featureGUID);
          return linkedFeature;
You see it in action in the next version of the EA Navigator :EANavigator_Setup_v2.4.4.0_beta.msi
« Reply #2 on: March 31, 2017, 05:10:00 pm »
David,
I'm interested in SBVR. Whatever you have will be very welcome.
Helmut Ortmann
« Reply #3 on: April 03, 2017, 04:27:14 pm »
Hi David,
could you please elaborate a bit on SBVR (Semantics of Business Vocabulary and Business Rules) and your experiences.
Thanks a lot!
Helmut
« Reply #4 on: April 04, 2017, 04:30:19 pm »
Hi David,
Thanks a lot!
Helmut
I'm afraid David is MIA, I've tried all communication means I could think of but no word from him yet.
I'll let you know if I hear from him.
