Author Topic: Where can I find the SQL scripts for visibility levels?  (Read 46635 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: August 03, 2023, 07:45:00 am »
According to https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/vl_config.html about setting up the Visibility Levels, the first thing I have to do is to run some SQL scripts for SQLServer. But... where are those scripts? they are not in the obvious place (https://sparxsystems.com/resources/repositories/index.html), so where are they located? I was looking for them also in the registered user section but they are not there.
Re: Where can I find the SQL scripts for visibility levels?
« Reply #1 on: August 03, 2023, 06:09:36 pm »
Send a bug report. These underlined text should be links.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: August 04, 2023, 12:56:43 pm »
The files will be installed by the ProCloud installer. See the help page you mentioned.
t-kouno
« Reply #3 on: August 05, 2023, 07:17:27 am »
You are right! I have just checked and they are in the folder: C:\Program Files\Sparx Systems\Pro Cloud Server\VisibilityLevels
