Author Topic: How can I get EA v15.2 to load EA v16.x QEA files?  (Read 9548 times)
avi10000
  • Programmer/Writer
« on: August 03, 2023, 08:10:41 pm »
Hi all,
EA 16.x creates an output file of type QEA.
Whereas EA 15.x creates an output file of type EAPX.
When we got our new licenses I downloaded 16.x (because I naturally thought it would be better).
I created a small model with it (16.1).
But I found EA 15.2 to be a lot faster when creating certain types of SysML diagrams.
Question: So I tried loading the new model (type QEA) with v15.2 and it would not load. How can I get EA v15.2 to load v16.x QEA files?
Avi
Re: How can I get EA v15.2 to load EA v16.x QEA files?
« Reply #1 on: August 03, 2023, 10:41:18 pm »
Try renaming the file type. If that won't work: it's not backward compatible.
P.S. See the other post/link. QEA is SQLite, EAPX is still some M$Access stuff (but 64 bit?).
« Last Edit: August 03, 2023, 10:44:50 pm by qwerty »
avi10000
  • Programmer/Writer
« Reply #2 on: August 03, 2023, 11:37:31 pm »
I tried. It did not work.
Wonderful !  :-\ :-\ :-\
Another way would be to try to export from the EA 16.x app the entire model to some XMI format. And then try to import it into the EA 15.x app.
« Reply #3 on: August 04, 2023, 08:14:50 am »
Yes. Support for .qea was added in 16.0, no older version can open it.
If you want a file format that both versions can open, use .feap. Or you can install the 32 bit version of 16 to still be able to exit .eap/.eapx.
As for the model you already have, Settings > Model > Transfer
avi10000
  • Programmer/Writer
« Reply #4 on: August 04, 2023, 07:07:14 pm »
Thanks. WFH right now and don't have v16 set up right now on any of my machines.
Under which ribbon/group tab would I find that 'Settings' command? Will try when I get back to office.
avi10000
  • Programmer/Writer
« Reply #5 on: August 04, 2023, 07:10:33 pm »
(quoting myself...)
I did that export from EA 16 to XMI and then then an import to EA15. Worked just fine.
But that was a very small model. of course, don't know what would happen if I tried that an a huge model with tens of 1000s of elements.
« Reply #6 on: August 07, 2023, 08:28:22 am »
Settings is the ribbon you need to look in. Model is the Group within that and Transfer is a menu button that offers different options.
