Author Topic: Problem with ReleaseUserLock or ReleaseUserLockRecursive in EA repository  (Read 10172 times)
I was looking for solution for release locks on choosed package in project browser.
I read that it was not available in EnterpriseArchitect a long time ago, but it is currently included in the documentation here: https://www.sparxsystems.fr/resources/user-guides/automation/enterprise-architect-object-model.pdf therefore I would expect that it is already operational. Could someone help me what am I doing wrong?
!INC Local Scripts.EAConstants-VBScript
sub main
    Dim Repository As EA.Repository
    Set Repository = GetObject(, "EA.App").Repository
    'actual package
    Dim SelectedPackage As EA.Package
    Set SelectedPackage = Repository.GetTreeSelectedPackage
    if Not SelectedPackage Is Nothing Then
            Dim status
            Set status = SelectedPackage.ReleaseUserLock(True, True, True)
            if status = 1 Then
                Session.Output("Unlocked")
            else
                Session.Output("failed")
            end if
    Else
        Session.Output("Není vybraný")
    End if
end sub
main
I find it interesting that this code ends up with the error "requested object", yet the lock is removed from the package. I couldn't even achieve this result in JS...
I tried using both VB and JS script. Next, I managed to check t_secuser where I have UserSecurity enabled in t_secpolicies and at the same time database administrator permissions
As I told you on SO this function returns a bool and not an objet (which you did declare wrongly btw.). Maybe you should practice VB a bit?
Ok than, let make it more simple. This code has still problem with procedure ReleaseUserLockRecursive "Problem with Sub procedure"...
option explicit
sub main
    'actual package
    Dim status
    SelectedPackage.ReleaseUserLockRecursive(True, True, True)
    Else
        Session.Output("Not chosen")
    End if
end sub
main
Any recommendation from Sparx?
Well, I used the suggested syntax in the editor:
Dim status
status = SelectedPackage.ReleaseUserLock()
which did run. Of course it failed since I have not set locking. Why did you supply these parameters. Did you RTFM? It doesn't show any. And the intellisense neither. Once in a while Sparx is not to blame...
Now, how do I get the dirt off my fingers???
This is again a syntax error. You are not allowed to use parentheses when calling a function and not using it's return type.
Correct alternatives are
    SelectedPackage.ReleaseUserLockRecursive True, True, Trueor
    status = SelectedPackage.ReleaseUserLockRecursive(True, True, True)
Hi Geert, many thanks for your comment. Now I have tested it and it has started worked for me.
    Else
    End if
Interesting. The linked documentation says the operation does not take any parameter at all. And (IIRC) when testing the intellisense did also suggest no parameter.
P.S. Only ApplyUserLockRecursive takes three bools.
« Last Edit: August 29, 2023, 02:43:31 am by qwerty »
It's only ReleaseUserLockRecursive that has the parameters
From the manual:
ReleaseUserLock ()
Boolean
Notes: Releases user locks and group locks from the Package object, and all of the Packages, diagrams and elements contained within that Package. User Security applies to the use of this function; if the user does not have permission to apply or release locks on elements, diagrams and Packages, the operation will fail.
Returns True if the operation is successful; returns False if the operation is unsuccessful. Use GetLastError() to retrieve error information.
ReleaseUserLockRecursive (boolean IncludeElements,
boolean IncludeDiagrams,
boolean IncludeSubPackages)
Boolean
Notes: Releases user locks from the Package object, and all of the Packages, diagrams and elements contained within that Package. User Security applies to the use of this function; if the user does not have permission to apply or release locks on elements, diagrams and Packages, the operation will fail.
Parameters
IncludeElements: Boolean - Recursively release user locks from child elements
IncludeDiagrams: Boolean - Recursively release user locks from child diagrams
IncludeSubPackages: Boolean - Recursively release user locks from child Packages
Hmm. The above linked docu differs...
P.S. It's a bit outdated? (From 2016) and does not mention the EA version it's made for. At least not obviously.
P.P.S. And it refers to the French Sparx site...
« Last Edit: August 29, 2023, 02:47:59 am by qwerty »
