Author Topic: Import DB ends with Unspecified Error  (Read 40439 times)
slavok1
« on: September 06, 2023, 09:05:22 am »
I am trying to import Oracle Database into an existing project. The last import was about 2 years ago
(I don't know if it was a clean import of a new DB or if the DB project already existed in EA and that was the last time it was synchronized with the current database).
Since there have been changes in some tables in 2 years, I would like to update the existing project in EA, at least as far as Tables and Views are concerned.
I have the connections created, I start the import, and everything starts up until I get to the step where the tables start importing/synchronizing sequentially. Everything runs beautifully until at one point the whole process stops with the following "Unspecified error" message. https://1drv.ms/i/s!AvjD_mFzlH_Eiqt-BEGRuX6SUK6Hag?e=UJeKNf
Is it possible to get a log from somewhere and find something from the log file? Where would I find this file? Alternatively, if anyone had a similar problem how did they solve it?
Last Edit: Today at 09:10:39 am
- Attachments and other options
« Last Edit: September 06, 2023, 09:24:27 am by slavok1 »
Re: Import DB ends with Unspecified Error
« Reply #1 on: September 06, 2023, 07:25:14 pm »
In %appdata%/sparx* you should find a dberror.txt which might contain the offending SQL. That's all you would get.
slavok1
« Reply #2 on: September 06, 2023, 07:49:38 pm »
Thanks for info, I have had found the file but it contains only one Error description from May 2023, which is not my current case.
« Reply #3 on: September 06, 2023, 08:50:04 pm »
Consider mailing Sparx support for that one.
