Author Topic: Improve performance of EA.Attribute.update  (Read 10706 times)
Ian Mitchell
« on: September 13, 2023, 01:44:33 am »
I have an application which needs to create a lot of new EA classes, each with some class attributes.
I have done all the performance tricks I can think of, including Repository.EnableUIUpdate=false, but the slow part of the process still seems to be the update to each attribute, after it is created: EA.Attribute.update.
Does anyone have any ideas for making this faster?
For scale, I have about 100 classes to create, and about 5-10 attributes for each one, so i'm cool that 500-1000 attributes will take a while, but if there is any way to make it faster, that would be great.
www.eaDocX.com
www.theartfulmodeller.com
Re: Improve performance of EA.Attribute.update
« Reply #1 on: September 13, 2023, 04:56:00 pm »
I don't think there's much you can do, except for inserting records in the database directly; but that is so naugthy even I don't do that.
Ian Mitchell
« Reply #2 on: September 13, 2023, 10:43:58 pm »
Really? Not even once, when you really needed to make it go fast?
Thanks anyway
www.eaDocX.com
ea0522
« Reply #3 on: September 13, 2023, 10:51:29 pm »
Would it be possible to split the action in some smaller actions?
I could imagine there might be a performance penalty in keeping the updates before the final commit.
Which could be tricked with multiple commits in between.
Or maybe using excel for importing?
« Reply #4 on: September 13, 2023, 11:02:53 pm »
t_attribute.Update is the smallest possible operation and it commits immediately.
With excel you would still need the updates, so that doesn't make a difference.
« Reply #5 on: September 13, 2023, 11:04:10 pm »
Thanks anyway
No, honestly; never done that
« Reply #6 on: September 14, 2023, 08:18:53 am »
I don't think there's much you can do except for inserting records in the database directly, but that is so naughty even I don't do that.
90% of our repository management is via direct DB manipulation (and has been so for the last decade and more).  If it's naughty, then like Brian, "I'm not the Messiah, just a very naughty boy!"
Once you get over your initial apprehension, it's not that hard.  Qwerty's magic books help a lot!
Modesto Vega
« Reply #7 on: September 15, 2023, 06:40:27 pm »
Hi Ian, are you using a direct database connection or going through PCS? Are you running 32-bit or64-bit?
My experience is that running operations through PCS performs better than direct database connections.
