Author Topic: [Ask] Ask about enum tagged value  (Read 14899 times)
demian824
« on: September 19, 2023, 10:40:07 pm »
Hello Professors,
I have a question about tagged value. I try to create two tagged value with enum type, Category and sub-category. Is there any way to change sub-category list follow by category selection, programmatically?
WonChul Choi
Re: [Ask] Ask about enum tagged value
« Reply #1 on: September 20, 2023, 12:04:44 am »
I'm not a professor, but I'm pretty sure that is not possible.
You cannot change the allowed values of a tagged value at runtime.
Can could either
- merge the two into one: eg. cat1-sub1, cat1-sub2, cat2-sub1
- validate/correct the allowed values after the user chose them
- create two separate stereotypes for your categories (possibly inheriting from a common abstract stereotype)
demian824
« Reply #2 on: September 20, 2023, 12:12:45 am »
Hello Geert,
Thanks to know  :)
WonChul Choi
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: September 20, 2023, 10:02:17 am »
Hello WonChul Choi,
You may realise it by using the TagGroup setting. For detail, see the following page:
https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_frameworks/define_tag_groupings.html
t-kouno
« Reply #4 on: September 20, 2023, 03:33:29 pm »
Hello WonChul Choi,
Hi Takeshi,
Could you explain how taggroups solve the problem of having different values in the sub-category depending on the selected category value?
Takeshi K
« Reply #5 on: September 21, 2023, 10:49:21 am »
Hi Geert and all,
I realised that I had misunderstood WonChul Choi's question. Geert's comment made me reread the original post and found my misunderstanding.
Sorry for the confusion...
t-kouno
ea0522
« Reply #6 on: September 21, 2023, 04:20:57 pm »
Reading the documentation on TagGroups I was wondering.
Suppose you define a TagGroup for each sub-category.
Would it then be possible to programmatically open/close (fold/unfold) each sub-category group depending on the value of the Category selected?
The program being triggered when the selection changes.
« Reply #7 on: September 21, 2023, 05:13:36 pm »
I'm not aware of any functionality supporting this.
« Reply #8 on: September 21, 2023, 05:17:44 pm »
I don't think we can do that ourselves.
For BPMN something similar happens, but IIRC that was programmed in by Sparx.
« Reply #9 on: September 21, 2023, 09:07:01 pm »
Reading the documentation on TagGroups, I was wondering.
For BPMN, something similar happens, but IIRC, that was programmed in by Sparx.
And, as usual, the implementation is defective!  If you select Task, the Task Group opens (and the others close); however, if you select Sub-process, the Task Group closes, but the Sub-process Group remains stubbornly closed!  You have to open it manually!
I'm sure if I report the defect, I will be told - "this is by design..."
Sheesh!
