Author Topic: Addition (plus sign +) does not work as expected in .qea (SQLite) repositories  (Read 7589 times)
Heidi V.
When running the following query on a .qea repository using the model search facility
select 1+1 as addition;
the result is 11.
When running the same query from within DBeaver and on the command line using SQLite, the result is 2.
For some reason, a string concatenation is done in EA.
This apparently has been reported to Sparx earlier, see https://sparxsystems.com/forums/smf/index.php/topic,46874.msg273987.html#msg273987, but is not fixed yet in 16.1.1627.
I've submitted a bug report as well.
