Author Topic: Editing the publishing templates  (Read 7618 times)
KalpakD
« on: October 15, 2023, 12:59:20 am »
I need to customize a template that is used for publishing a diagram.
Do I need to dive into editing it via XML way?
Our is there a tool in EA?
Specifically, I don't want to publish the author and version information in the report.
thanks,
wivel
  • Driven by Models
Re: Editing the publishing templates
« Reply #1 on: October 15, 2023, 10:20:25 am »
Are you talking about HTML publishing?
Henrik
Sunshine
  • Its the results that count
« Reply #2 on: October 16, 2023, 06:21:50 pm »
Publishing manuals for HTML and documents can be found here.
https://www.sparxsystems.com/resources/user-guides/16.1/index.html#publishing
Can use built in document editor to create templates or edit the HTML templates in the editor.
Happy to help
KalpakD
« Reply #3 on: October 19, 2023, 11:52:41 pm »
I missed out in asking about the file format of output.
I want to avoid making all the viewers install the free EA viewer.
So, which output format will keep it as close to the original as possible?
For example, pdf does not seem to support hyperlinks in the document.
So, viewer will find it difficult to navigate through the document.
HTML seems better at that.
Any other common file formats?
thanks,
