Author Topic: Connector Appearance shows different thickness with same settings  (Read 3819 times)
ea0522
On a diagram I have several objects of the same type and connected with the same connector type.
When I change the appearance of some connectors, they look different.
What I change is the color and thickness. The difference is in the thickness. The color is showing ok.
The effect is in several combinations of element and connector types.
The last diagram I have it, it shows differences between ArchiMate ApplicationComponents and Nodes, connected with Flows To and Serving connectors.
Any suggestions on how to fix this?
Refreshing / reloading the diagram doesn't work.
It even shows the differences in the images generated for the WebEA pages.
