Author Topic: Can I use EA as frontend to run SQL queries on SQL server database?  (Read 11028 times)
Richard Freggi
Hello, EA 16 professional, *.qea project on my PC.  I'm reverse engineering a SQL Server database; the ODBC connection worked fine.  However I need to query the database system views to extract the DDL of views and procedures and view/procedure attributes (it was not retrieved with the reverse engineering).  I've done this before using DBeaver, but I don't have JDBC connection to this database.  Does EA have a SQL terminal window that I can open and run my queries on a non-project database?  Can the results be exported as csv.  I really don't want to install SSM or Azure studio.  Thanks!
Re: Can I use EA as frontend to run SQL queries on SQL server database?
« Reply #1 on: October 20, 2023, 03:26:56 pm »
Yes, from the database builder you can execute queries on the target database.
https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_domains/dbexplorer_scratchpad.html
Richard Freggi
« Reply #2 on: October 20, 2023, 03:31:06 pm »
*sad noises* thanks Geert but professional does not have DB builder I think...
« Reply #3 on: October 20, 2023, 03:35:44 pm »
Could be. EA licenses start at Corporate for me.
Nobody should be using professional in a professional context.
Richard Freggi
« Reply #4 on: October 20, 2023, 11:29:09 pm »
When I did the trials I did not notice any major benefits in Corporate - for example the database builder thing is something I can do better myself I thought.  What benefits do you see in Corporate version?  Genuinely interested to know.
« Reply #5 on: October 20, 2023, 11:45:26 pm »
- use a database backend
- scripting
Without those (especially the first) it's only good for hobbyists (or solo modellers)
EA's Corporate licenses are dirt cheap, the price difference between Professional and Corporate amounts to just a couple of hours work max (in Europe), so it's an easy ROI.
« Reply #6 on: October 21, 2023, 03:25:07 pm »
- scripting
EA's Corporate licenses are dirt cheap; the price difference between Professional and Corporate amounts to just a couple of hours work max (in Europe), so it's an easy ROI.
Wot 'e sed!
Plus, I find Database Builder (for Reverse Engineering at least) a big improvement on its predecessor.
