Author Topic: How to best find the superclass of a given class in script  (Read 4504 times)
StefanBrandmeier
« on: November 21, 2023, 04:02:51 am »
Hi community,
I am looking to programmatically find the superclass of a given class in my diagram, trying to do this with the relationships of the class:
         //   find the superclass
         while ( !connectorsEnumerator.atEnd() )
            connectorToCheck = connectorsEnumerator.item();
            if(connectorToCheck.Type = "Generalization")
               parentElement = Repository.GetElementByID(connectorToCheck.SupplierID);
               break;
            connectorsEnumerator.moveNext();
Neither ClientID nor SupplierID of the connector seems to point to the superclass. What am I missing ?
Or is there a better way to find the superclass of a related element of a diagram element ?
Thanks for your thoughts on this.
Cheers
Stefan
Re: How to best find the superclass of a given class in script
« Reply #1 on: November 21, 2023, 04:46:21 am »
There is a property Element.BaseClasses you can use.
Why are you using the connectorsEnumerator?
Can't you simply loop over the element.Connectors with something like a foreach?
Your logic should be fine otherwise.
StefanBrandmeier
« Reply #2 on: November 21, 2023, 07:41:19 pm »
Hi Geert,
thanks for you quick and competent reply. I will try Element.BaseClasses which will be much simpler of course.
As to the iterator, I guess my JScript skill is pretty basic and I don't yet know all its possibilities. Thanks for the hint.
Cheers
Stefan
StefanBrandmeier
« Reply #3 on: November 21, 2023, 09:12:31 pm »
Here's some working code, based on Geerts suggestion, if someone is interested:
         var baseClasses as EA.Collection;
         //   find the superclass, don't consider if multiple superclasses exist.
         baseClasses = relatedElement.BaseClasses;
         if (baseClasses.Count == 1)
            parentElement = baseClasses.GetAt(0);
