Author Topic: Ways to edit "field codes" in document templates  (Read 2952 times)
StefanFS
« on: November 22, 2023, 03:38:02 am »
the document generation in EA is somewhat "un-sophisticated". I'm having a lot of issues with the standard tools provided, e.g. with inserting sections in a document template. Selecting the sections from the board works, but moving the tags later to a different position seems to be impossible. Therefore, I have the following question:
Is there any possibility to edit the "code" used to generate the sections and other hidden information in the document template (something similar to editing the field codes in MS Word)?
I would very much appreciate any feedback on this point!
Kind regards,
Stefan
Re: Ways to edit "field codes" in document templates
« Reply #1 on: November 22, 2023, 05:40:26 am »
Hi Stefan,
I'm afraid you are out of luck.
But the good news is that, with enough effort an patience, almost anything is possible.
Moving stuff to a different position can either be done by
- cut/paste, making sure you include the right section markers.
- first move the section up/down on the left pane, and then insert it into the document.
Also, sometimes EA (or is it the user) messes up and breaks a template beyond repair.
Make sure to enough enough backups or copies to go back to, because once a template is broken, there is no way to fix it anymore. You can only delete it and recreate it.
