Author Topic: Change author name for all diagrams and elements  (Read 8963 times)
EA_enthusiast
  • I'm a lifelong learner
« on: November 23, 2023, 01:47:50 pm »
Hello EA experts,
I know this question has been discussed a few times in the past several years. The last time (I came across) was around 2015. Is there a new and easy way to change the author name for all diagrams and elements?
Thank you!
Thank you to all the contributors who spread their knowledge and experience!
vladap
Re: Change author name for all diagrams and elements
« Reply #1 on: November 24, 2023, 03:49:09 am »
I see three options:
- change in the Database, so that´s easy DB update
- export XML and rewrite it
- you can go to scripting and write JS which goes through all elements and change it
V.
wivel
  • Driven by Models
« Reply #2 on: November 24, 2023, 04:29:04 am »
Hi
Have changed element author names numerous times using SQL directly on the database. Easy and fast.
Henrik
EA_enthusiast
« Reply #3 on: November 24, 2023, 09:19:49 am »
Thank you, vladap and wivel, for your responses.
Is there a step-by-step guide (somewhere) that I can follow for any of these options, as I have not done this before?
vladap
« Reply #4 on: November 24, 2023, 09:35:28 pm »
UPDATE t_diagram
SET Author = 'John'
WHERE Author='Adam';
UPDATE t_object
SET Author = 'John'
« Reply #5 on: November 24, 2023, 11:15:07 pm »
To be honest, changing the author directly in the database is somewhat of a nuclear Sledge Hammer option (Trust me, I know what I'm doing)
When not careful this can mess up your model in so many ways.
This circumvents EA completely (and every write protection on the model)
The somewhat more careful option is to use a script
There are a few scripts in the local scripts that traverse a model. You can start with one of those, and update the author in the elements or diagrams you process.
something like
dim element as EA.Element
for each element in package.Elements
    if element.Author = "John" then
        element.Author = "Adam"
        element.Update
    end if
next
Sunshine
  • Its the results that count
« Reply #6 on: November 26, 2023, 10:53:28 am »
Here is some jscript  I wrote some time ago for changing elements author. It might help you get started.
//!INC Local Scripts.EAConstants-JScript
// Name: Change Author
// Changes the author names to be consistent
// NOTE: Requires a package to be selected in the Project Browser
// Related APIs
// Element API - http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/element2.html
// Repository API http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/repository3.html
// Tagged Value API http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/taggedvalue.html
function StartWithSelectedPackage()
    // Show the script output window
    Repository.EnsureOutputVisible( "Script" );
    Session.Output( "JScript Change Author" );
    Session.Output( "===========================" );
    var thePackage as EA.Package;
    thePackage = Repository.GetTreeSelectedPackage();
    if ( thePackage != null && thePackage.ParentID != 0 )
        NavigatePackage( "", thePackage );
    else
        Session.Prompt( "This script requires a package to be selected in the Project Browser.\n" +
            "Please select a package in the Project Browser and try again.", promptOK );
    Session.Output( "Done!" );
// Outputs the packages name and elements, and then recursively processes any child
// packages
// Parameters:
// - indent A string representing the current level of indentation
// - thePackage The package object to be processed
function NavigatePackage( indent, thePackage )
    // Cast thePackage to EA.Package so we get intellisense
    var currentPackage as EA.Package;
    currentPackage = thePackage;
    // Add the current package's name to the list
    Session.Output( indent + currentPackage.Name + " (PackageID=" +
        currentPackage.PackageID + ")" );
    // Convert the elements this package contains
    ProcessElementsInPackage( indent + "    ", currentPackage );
    // Recursively process any child packages
    var childPackageEnumerator = new Enumerator( currentPackage.Packages );
    while ( !childPackageEnumerator.atEnd() )
        var childPackage as EA.Package;
        childPackage = childPackageEnumerator.item();
        NavigatePackage( indent + "    ", childPackage );
        childPackageEnumerator.moveNext();
// Converts the elements of the provided package to the Script output window
// Parameters:
function ProcessElementsInPackage( indent, thePackage )
    // Iterate through all elements and add them to the list
    var elementEnumerator = new Enumerator( currentPackage.Elements );
    while ( !elementEnumerator.atEnd() )
        var currentElement as EA.Element;
        currentElement = elementEnumerator.item();
        ProcessElements(indent+"    ",currentElement );
        elementEnumerator.moveNext();
function ProcessElements( indent, theElement )
    // Cast theElement to EA.Element so we get intellisense
 // Debug Comment out when run for real
    Session.Output( indent + "CALLED: ProcessElements for element " + theElement.Name );
    currentElement = theElement;
    currentElement.ObjectType
    ChangeAuthor(indent+"    ",currentElement );
    // Iterate through all embedded elements and add them to the list
    var elementEnumerator = new Enumerator( currentElement.Elements );
// Changes name of author
// Parameters:
// - theElement The element object to be processed
function ChangeAuthor( indent, theElement )
    Session.Output( indent + "CALLED: ChangeAuthor(" + theElement.Name + ")" );
    // If stereotype matches source list then convert
    if  (theElement.Author=="Old author name")
        Session.Output( indent + "    Changed Author: " + theElement.Name );
         //uncomment stuff below to actually do conversion.
theElement.Author = "New Author Name";
        //Overright the stereotype list to have only one stereotype
theElement.Update();
StartWithSelectedPackage();
Happy to help
EA_enthusiast
« Reply #7 on: December 10, 2023, 12:12:15 pm »
Thank you, Geert and Sunshine, for your responses. I appreciate your help.
