Author Topic: Import a diagram (.xml)  (Read 11303 times)
pmanzo
« on: December 07, 2023, 02:43:42 am »
Hello network,
I have a problem while importing a .xml from a project to another one.
Even if the SysML is correctly imported, the images are not copied leaving a white rectangle w/o any content inside.
It seems that only the dimension of the picture has been imported but not the content.
Any idea?
Re: Import a diagram (.xml)
« Reply #1 on: December 07, 2023, 02:47:35 am »
You can't import diagrams, you can only import packages.
If the elements on your diagram are located somewhere else, they won't be included in the xml export.
pmanzo
« Reply #2 on: December 07, 2023, 07:56:47 pm »
Yes, correct. I`m importing package but the images remain blank w/o content.
Any idea to import also the content of the images while importing a package?
« Reply #3 on: December 07, 2023, 09:21:06 pm »
Do you by any chance mean image (png, etc.) data?
pmanzo
« Reply #4 on: December 07, 2023, 10:42:52 pm »
Yes, I`m referring to image data (.png).
« Reply #5 on: December 07, 2023, 11:14:33 pm »
There's an option in the XML export settings somewhere (use a machete to find your way through the options jungle - good luck).
