Author Topic: Default appearance  (Read 8273 times)
EA_enthusiast
  • I'm a lifelong learner
Default appearance
« on: December 21, 2023, 11:55:53 pm »
Hello EA experts,
I changed the default appearance of an element (as shown below)
https://ibb.co/3Cd9f3H
But I am not sure why it's not reflected in other diagrams (as shown below)
https://ibb.co/rcYWQ9m
Thank you!
Thank you to all the contributors who spread their knowledge and experience!
BobM
Re: Default appearance
« Reply #1 on: December 22, 2023, 12:22:00 am »
Something tells me you are using a legend element on the second diagram which changes the appearance of the elements.
EA_enthusiast
« Reply #2 on: December 22, 2023, 01:57:04 am »
Thank you, Bob for your response. I am not the one who created the second diagram.
I didn’t see a legend element on the diagram. But, I’ll check the diagram as soon as I’m in front of my machine and report back.
EA_enthusiast
« Reply #3 on: December 22, 2023, 04:15:40 am »
I have just checked the second diagram, and I do not see any diagram legend. I am not sure what prevents the new default appearance from being displayed.
« Reply #4 on: December 22, 2023, 06:06:41 am »
your linked pict are empty / gone. So I just guess: you can set appearance for either just a diagram or for the entire model. EA does not make it easy to distinguish them.
EA_enthusiast
« Reply #5 on: December 22, 2023, 07:14:48 am »
Thank you, qwerty, for chiming in.
The 2 diagrams in the original post are still there if you would like to check them out.
When I hover over the "default appearance", a tooltip appears indicating that the default appearance will be changed in all diagrams. Please see the below screenshot.
https://ibb.co/tsyjd1J
« Reply #6 on: December 22, 2023, 11:58:10 pm »
Chances that the other diagram has a local overwrite for the global appearance...
EA_enthusiast
« Reply #7 on: December 23, 2023, 09:05:42 am »
Thank you, qwerty. Do you know how can I check/remove that?
EA_enthusiast
« Reply #8 on: December 23, 2023, 07:20:03 pm »
In case someone came across the same issue. You have to click on Layout > Appearance > Reset Local Appearance
https://ibb.co/Csp5snL
« Last Edit: December 24, 2023, 05:12:28 am by EA_enthusiast »
« Reply #9 on: December 24, 2023, 07:55:36 am »
You can find locally overwritten appearance via scripting or SQL if you need to check that more often.
EA_enthusiast
« Reply #10 on: December 24, 2023, 08:29:32 am »
Thank you, qwerty, for the tip.
