Author Topic: Importing or converting an architectural mode in PDF to EA. Possible?  (Read 14455 times)
EA_enthusiast
  • I'm a lifelong learner
Hello EA experts,
Is there any tool or a way to import/convert an architecture model in a PDF format to EA / EA file format?
Thank you!
Thank you to all the contributors who spread their knowledge and experience!
Re: Importing or converting an architectural mode in PDF to EA. Possible?
« Reply #1 on: December 27, 2023, 02:19:23 am »
Simply: no, except for using eyes/brain/fingers to do the transformation.
EA_enthusiast
« Reply #2 on: December 27, 2023, 03:36:19 am »
Thank you, qwerty! I heard of some tools and addins that convert PDF to Visio. I was curious whether something similar exists for EA.
steen.jensen
« Reply #3 on: December 27, 2023, 10:16:15 am »
Soon it should be possible for some AI.
Bing AI can describe element and relations from an Archimate jpg picture. It does not understand the Element-type yet, and I was trying to get the textual in Exchange Format but did not succed.
Maybe some payed version can do it already
EA_enthusiast
« Reply #4 on: December 30, 2023, 02:52:11 am »
That makes sense, Steen. I would expect to see a reasonable solution to this problem in the next 1-2 years.
Jan van Duuren
« Reply #5 on: January 02, 2024, 11:57:13 pm »
You could use NODEJS with a PDF text Reader package (npm) to open your EA repository and PDF-Files to create elements.
such script will not run inside EA, but on Windows itself.
Steps you would need are:
  • download and install nodejs engine from Internet
  • installl npm package 'winax' to use ActiveXObjects (COMObjects)
  • install npm package 'pdf-text-reader'
  • create a js script in which you:
    • open your EA repository as ActiveXObject
    • retrieve required info from PDF file
    • create EA elements retrieved from PDF
    • close EA repository
« Last Edit: January 03, 2024, 12:10:18 am by Jan van Duuren »
EA scripting since 2013 (JScript, Javascript and Node.js)
EA_enthusiast
« Reply #6 on: January 09, 2024, 06:35:30 am »
Thank you, Jan, for sharing this. I am wondering whether you have tried this yourself and it worked for you?.
Jan van Duuren
« Reply #7 on: January 17, 2024, 06:50:27 pm »
Yes, I did use it for retrieving some documentation from multiple PDFs.
I grabed all PFD files, itterate through each PDF file, searched for some fixed text (tags) and then inserted them as new elements in EA.
So it is doable and repeatable.
EA_enthusiast
« Reply #8 on: January 20, 2024, 04:03:44 am »
This is nice! I should try it, then. Thank you, Jan.
