Author Topic: Searching and editing links in Notes  (Read 6539 times)
shimon
« on: January 22, 2024, 09:34:16 pm »
We used (part of the) notes on elements to link to documents. As the directory name of some of these documents were in Hebrew, these hyperlinks do not render properly ( and do not work) in any RTF Documentation.
The work-around that seems to work is to create a file in a directory who's path is only in English that links to the original file.
The problem is to find all these links. The capability of viewing the present path  for a hyperlink in the Notes is non-existent in EA.
Using the SQL to search the Notes did not bring any results as explained by Geert here:
https://sparxsystems.com/forums/smf/index.php/topic,47483.msg276791.html#msg276791.
After figuring this out (and giving the Notes column an alias) I have to figure out the syntax for striping the Notes and leaving only the Hyperlinks.
Another option is to find non-English characters in a Hyperlink.
Sincerely,
Shimon
P.S. If anyone has done this already, please share.
Re: Searching and editing links in Notes
« Reply #1 on: January 22, 2024, 09:57:40 pm »
I think the best option is to create a small script to update your notes.
If you have a list of before/after paths, you can loop those and updates the notes one by one.
That will probably be easier (and safer) than trying to write an update query.
shimon
« Reply #2 on: January 23, 2024, 12:28:17 am »
Hi Geert,
I'm not looking to update via SQL. I'm just looking for a way to find all the notes that have such links.
I found it by searching for :
where t_object.notes like '%href%&#%\'.
It could probably be perfected, but this did the job for me.
Sincerely,
Shimon
