Author Topic: Report Builder: Outputting a Diagram Image once you have the Diagram_ID  (Read 4396 times)
Ribeye
I am building a report using Report Builder.
One component of the report requires selecting Diagrams using SQL. I can then use "Insert customer field" to output the Name and Notes etc. All good.
But I also need to output the Diagram Image. Cant find how to do that.
Can someone advise on approach?
Ribeye
Re: Report Builder: Outputting a Diagram Image once you have the Diagram_ID
« Reply #1 on: February 07, 2024, 11:29:45 pm »
My answer to date is that you cant. Switched to Scripts, abandon Report Builder.
« Reply #2 on: February 07, 2024, 11:43:51 pm »
Alternative aproach is to use virtual documents.
Selecting a single diagram is still not possible though. You have to select either a package, or an element, and you can filter on diagram type.
