Author Topic: Using Crystal Reports  (Read 3914 times)
Tatiana
« on: July 31, 2013, 10:27:24 pm »
Hi, I created a add-in on VS2010 .NET 4.0 using Crystal Reports. Every time I set the datasource I receive the message:
Could not load file or assembly 'file:///C:\Program Files (x86)\SAP BusinessObjects\Crystal Reports for .NET Framework 4.0\Common\SAP BusinessObjects Enterprise XI 4.0\win32_x86\dotnet1\crdb_adoplus.dll' or one of its dependencies.
Looking around I found that I Crystal is compiled in .NET 2.0 and I should add this to my app.config file:
<startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v4.0"/>
  </startup>
But that still don't work.
EA version is 9.3.
Any ideas?
Thank you.
« Last Edit: July 31, 2013, 10:27:34 pm by tatiperere »
Re: Using Crystal Reports
« Reply #1 on: July 31, 2013, 10:42:59 pm »
I don't see where this problem is related to EA  :-?
Tatiana
« Reply #2 on: August 01, 2013, 12:58:11 am »
I found that the configuration "useLegacyV2RuntimeActivationPolicy" must be in the side of the application that will call the add-in (.dll). In this case EA...  :-/
