Author Topic: Deleting Document Templates and Fragments via script  (Read 9694 times)
shimon
« on: January 31, 2024, 12:03:49 am »
I would like a simple script that deletes all documentation fragments and templates (based on the name).
Does anybody have a sample script that does this?
Shimon
P.S. I am a newbie as far as scripting is considered.
Re: Deleting Document Templates and Fragments via script
« Reply #1 on: January 31, 2024, 12:13:45 am »
I don't think those things are exposed in the API.
So the only option you have is to delete them from the database. IIRC you need to look at t_document
If needed you can execute the deletes from a script.
shimon
« Reply #2 on: January 31, 2024, 04:56:41 pm »
Thanks Geert,
That's what I thought, as I didn't find any reference to the objects in the table t_document (after about an hour of searching) in the documentation.
I would rather not go the DB route, so I wanted to combine a SQL search and delete object by GUID, but the t_document doesn't have a GUID and it seems that it is not an element of the Repository. I guess the DB route is the only way.
Sincerely,
Shimon
« Last Edit: January 31, 2024, 05:39:00 pm by shimon »
« Reply #3 on: January 31, 2024, 06:30:33 pm »
Correct, you can't delete them through the API.
There is an undocumented (and unsupported) method in Repository called Execute() that you can call, passing an insert/update/delete query as parameter, so it's not like you need to setup your own database connection to do that.
shimon
« Reply #4 on: February 01, 2024, 02:28:18 am »
Wow,
That's great news. I just tried it and it works like a charm.
Shimon
