Author Topic: Local Paths for code generation are not persisted  (Read 14189 times)
StefanBrandmeier
« on: February 15, 2024, 12:00:01 am »
Hello Sparx,
when defining and saving local paths they are not stored in the repository. After I close and reopen EA the paths are gone !
https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_domains/localpaths.html
Thanks for any help
Stefan
Re: Local Paths for code generation are not persisted
« Reply #1 on: February 15, 2024, 08:07:36 am »
They are a user setting and aren't meant to be saved into the repository. Check the environment that you're running EA, because if you're not seeing those preserved across settings there will be others that your environment will also prevent from working.
StefanBrandmeier
« Reply #2 on: February 22, 2024, 03:25:11 am »
Hi Eve, and thanks for your quick answer. I am aware that these are user settings and should be so. But where are they stored if not in the repository. Can you please point me to the location for users settings e.g., roaming profile folder etc. ? I can then follow up with IT support. I did browse the documentation for this but no success.
Thanks for any help
Cheers
Stefan
« Reply #3 on: February 22, 2024, 09:26:03 am »
Look into the %appdata%/sparx/ea folder where you find a file paths.txt
« Reply #4 on: February 22, 2024, 07:24:04 pm »
Hi Stefan,
If those paths get lost, there is probably an issue with your roaming profile not being saved when you log out.
You might want to check with the infra team to resolve this issue.
StefanBrandmeier
« Reply #5 on: February 22, 2024, 09:08:07 pm »
thanks querty and Geert - that helps me already
