Author Topic: List Property keeps being regenerated as an attribute - How to prevent?  (Read 14023 times)
RIL
  • -- There's always a solution --
For some reason some (several) list attributes which I turned into Properties, keeps being regenerated as List attribute again, causing conflict (due to duplicate identifiers).
Illustrated below the Property "CoElements" is re-generated as a list attribute even if I delete it in the code and synchronize the code back up to EA. But when generating code the next time, that evil attribute is back in the code again. I have several of these cases, which requires manual clean up.
Q: Is there any way I can prevent EA from regenerating such extra attribute copies of what should only be a property? (plus its inner member).
public List<Co_Element> CoElements;     // Attribute keeps being regenerated - Irritating
private List<Co_Element> _CoElements; // "Inner member" as intended - OK
public List<Co_Element> CoElements;    // Property as intended - OK
    get
        if (_CoElements == null)
            _CoElements = new List<Co_Element>();
        return _CoElements;
//Rolf
« Last Edit: February 21, 2024, 11:07:52 am by RIL »
Re: List Property keeps being regenerated as an attribute - How to prevent?
« Reply #1 on: February 21, 2024, 11:16:46 am »
What does your model look like? What changes have you made to the code templates? If you do something equivalent with the original templates how does it behave?
Basically, the Code Templates that you can change are in balance with the grammars defined for the importer, which you can't change. If you change the code templates to generate something that doesn't match what the importer sees you will get this behavior. The only ways to prevent it are either to not make those changes or not reverse engineer the model from the code after it's generated.
RIL
« Reply #2 on: February 21, 2024, 01:28:28 pm »
Very simple. A few more lines than I already posted (it's just a small test case for some ideas I'm testing).
None. Just to make sure nothing spooky were lurking in the code templates, I created a new EA model (100% guaranteed untouched code template) and imported and generated, and the same happened again.
But, I noticed something strange with the newly imported model - it had two copies of the class which had the problematic links. That explains it. So I deleted the dupe and generated code, and the sun is shining again.
And no, I had NOT copied that class, at least not consciously. That copy was not visible in the Project Browser on the original model. Only now, when I imported the model into a new EA project, then EA put both copies on a auto-diagram and also showing the two classes in the Project Browser.
I honestly don't think so. As long as I have valid C# code (compiling in VS) I have so far not had any problem with EA importing it. Which means that EA knows the grammar, and no matter what kind of code I would generate with a modified template (which compiles in VS), EA seems to pick it up. No connection there.
Or if I put it another way; I do not make templates which produces invalid C# code which neither VS nor EA can  handle.
Hm, that doesn't seem to be irrelevant. What's relevant is that the C# code is valid. Well, so far EA 16.1 has handled import without any problem.
What I have noticed though is that sometimes EA doesn't show what it has in the database.  For example the Delphi project I posted about which had some 16.300 .pas files. I had to close EA and start it again before any of the ~20.000 classes would show in the Project Browser. Reminds about this problem where the Project Browser didn't bother show me I had a copy of a class (must have pressed CTRL-C, CTRL-V when not having focus in the right place... or something).
The developers would have reasons to  investigate why the UI doesn't always reflect the data...
//Rolf
« Last Edit: February 21, 2024, 01:33:11 pm by RIL »
RIL
« Reply #3 on: February 21, 2024, 03:24:36 pm »
Hm. After I restarted the EA Model (after importing the code into a new model) the link-problems are back again.
Had this been a problem with Rhino3d and me posting about it on their Forum, then one of the developers would have asked for a stripped down test project in order to hunt down the problem.
Anyway, something seems to get messed up in the database. Code example again below; A List Property insists on being reintroduced as a Link attribute, disregarding the fact that the Property with the same name already exist.
//Rolf
   private CoObject _CoClassMemberInfo;
   public CoClassMemberInfo CoClassMemberInfo; // <-- This sneaks in again and again...
      get
         if (_CoClassMemberInfo == null)
            _CoClassMemberInfo = new CoClassMemberInfo();
         return (CoClassMemberInfo)_CoClassMemberInfo;
      set
         Debug.Assert(false, "The CoClassMemberInfo property is read only");
« Reply #4 on: February 21, 2024, 09:10:50 pm »
Think about scripting the whole thing yourself. I did so years ago and it's by far easier than struggling with EA's pseudo-script oddities.
RIL
« Reply #5 on: February 22, 2024, 03:10:36 am »
I definitely have thought of it, but at this time I'm only testing out some little idea I have and so I won't have the time to start from scratch. I had hoped EA would have supported at least the most basic of tings.
Q: Anyway, can the code templates call external scripts (so I could at least do some point fixes here and there?)
//Rolf
« Reply #6 on: February 22, 2024, 09:30:00 am »
No idea since I do not touch that awkward stuff...
RIL
« Reply #7 on: February 22, 2024, 12:42:53 pm »
I begin to understand what you mean. :)
//Rolf
« Reply #8 on: February 22, 2024, 07:26:45 pm »
//Rolf
IIRC there is indeed a way to call an add-in function.
I found this snippet somewhere on this forum. I never used it myself though.
$opCode = %EXEC_ADD_IN("CS_Addin", "GetSignals", classGUID, classStereotype, ...)%
RIL
« Reply #9 on: February 23, 2024, 05:46:36 pm »
Thanks of that hint, I will definitely look into that!
//Rolf
