Author Topic: Exception from HRESULT: 0xE06D7363  (Read 8089 times)
Djaved
« on: August 02, 2013, 01:24:41 am »
Dear All,
I'm very new to EA and want to experiment with the c# API.
I'm using EA Lite and want to generate html reports from my eap files.
When calling :
project.RunHTMLReport(repository.ProjectGUID,
                                          "C:\\test",
                                          "NONE",
                                          "myEnterpriseArchitectStyle",
                                          ".html");
Im getting the error: Exception from HRESULT: 0xE06D7363
My question is why im getting this error and how to solve this?
Also, can i make .html reports with EA lite? and as you can see in my code, i'm using a custom style 'myEnterpriseArchitectStyle'.
Can this be the cause of my problem? And where exactly to put the custom style files? i cannot configure it using EA Lite.
I hope to get some help with this.
Thanks in advance.
Re: Exception from HRESULT: 0xE06D7363
« Reply #1 on: August 02, 2013, 01:33:11 am »
Try a google search for "HRESULT: 0xE06D7363"
I'm not sure whether you can use the API with Lite. Probably not.
« Last Edit: August 02, 2013, 01:34:04 am by qwerty »
Djaved
« Reply #2 on: August 02, 2013, 01:39:30 am »
Thanks for suggestion.
I already did a google search, but found nothing relevant.
Also i want to be 100% sure whether i can use EA Lite or not.
« Reply #3 on: August 02, 2013, 02:30:49 am »
Google told me some DLL error behind this. Probably because Lite does not deliver the needed API.
« Reply #4 on: August 02, 2013, 09:04:48 am »
The Lite version doesn't allow you to run reports via the gui. If it did allow you to do it from automation that would be a bug that would require correcting.
« Reply #5 on: August 02, 2013, 08:18:01 pm »
You don't expect a bug report the latter, do you? :-)
Djaved
« Reply #6 on: August 02, 2013, 09:27:37 pm »
Hi Simon,
FYI:
Using EA Lite, I'm getting a exception, but it creates a folder with html files and styles. Clicking the index.htm shows me a empty report.
Aaron B
« Reply #7 on: August 05, 2013, 10:14:46 am »
repository.ProjectGUID is not a valid target for the HTML report.  You need to pass a valid PackageGUID value.  For example:
project.RunHTMLReport(repository.Models.GetAt(0).PackageGUID,
"C:\\Temp",
"PNG",
"<default>",
".html");
Note: I haven't tested this with EA Lite.  As per SimonM's response, it would not be supported for that version as EA Lite is read-only and does not allow output of RTF or HTML documents via the GUI.
