Author Topic: Acceptance criteria.  (Read 6179 times)
TheBlueSki
« on: March 12, 2024, 08:32:36 pm »
Is there anyway to import acceptance criteria into EA against a lot  of requirements.  Some sort of automated way to process crteria based on a requirement name and add them as a test.
Re: Acceptance criteria.
« Reply #1 on: March 12, 2024, 08:40:32 pm »
I think you'll have to write a script to do so.
Maybe there is an excel import possible with the Office MDG, or EA Sheets as well https://www.eateamworks.com/easheets/
PDC
  • Systems Engineer
« Reply #2 on: March 13, 2024, 07:49:38 pm »
Might depend on exactly how you want to inspect the requirements and store the acceptance criteria.
A script would work for sure, but if the requirements have consistent enough naming then you could export them as a csv, filter the list in Excel ( :D) and add the acceptance criteria as e.g. a new Tagged Value. Then re-import the csv. Probably take about 5 minutes in total, so could feasibly be re-run as often as required.
Phil
