Author Topic: How to remove unwanted links from SysML1.4::requirement  (Read 22211 times)
MichPaule
« on: March 14, 2024, 02:24:15 am »
EA 16.1.1628 (64 bit)
Trying to trim the linking capabilities to the users needs...
The process demands <satisfy> links from SysML Block to SysML Requirement and <refine> links from UseCase to SysML Requirement (please don't ask why 8) ).
I have successfully created the stereotyped relationships and linking is possible.
But I can't get rid of the standard QL links (Satisfies & Refines) no matter what I tried.
Both are always there when trying to link to a requirement.
I was expecting only the single link I configured using the stereotyped relationships.
According to https://sparxsystems.com/forums/smf/index.php/topic,44252.msg260847.html or https://sparxsystems.com/forums/smf/index.php/topic,48190.msg279985.html#msg279985 there seems to be a way.
But after hours of trying I'm still unable to figure out how follow the instructions given in Define Metamodel Constraints.
Would someone please help me out of my despair?  :-[
TIA for your support!
Michael
Re: How to remove unwanted links from SysML1.4::requirement
« Reply #1 on: March 14, 2024, 08:05:45 am »
You may be able to do it with a restricted perspective.
https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_fundamentals/techno_sets.html (scroll down a bit)
You can also assign a perspective to a security group.
MichPaule
« Reply #2 on: March 14, 2024, 07:25:12 pm »
Thanks Eve,
I just had a deeper look into this.
Unfortunately I didn't find a way to remove the <refine> linking option although in Restrictions / SysML 1.5 / Link Rules I deselected under Link Type: Refine the entry Block <-> Requirement.
Still the <refine> link is possible between a Block and a Requirement, even after closing/opening the model and selecting the created model-based perspective.
As my MDG was not involved at all (only plain SysML 1.5) I would expect the restriction should apply.
Did I find a bug here?
Michael
MichPaule
« Reply #3 on: March 14, 2024, 09:21:02 pm »
Success!
Got it working without restricted perspectives.
The key was to remove the unwanted <refine> relation by creating a Stereotyped Relationship with Stereotype=SysML1.4::refine from my Block (Source) to the <none> metaclass (Target).
The documentation somehow suggests the other way around - which doesn't do the trick.
This answer of Eve
Removing them requires creating a constraint for the existing relationship types targeting the metaclass '<none>'.
gave me the hint ;)
Michael
