Author Topic: Open EA internal web browser - ShowBrowser  (Read 7731 times)
Martin Trneny
« on: August 06, 2013, 06:48:55 pm »
we need to preview html code from a note of an object element.
I find method (in scripting) Repository.ShowBrowser(String, String) but it isn't working. The documentation doesn't exist at all :(. There is Repository class documentation but no word about ShowBrowser.
Do you have any idea how this method works?
Martin
Re: Open EA internal web browser - ShowBrowser
« Reply #1 on: August 06, 2013, 07:13:29 pm »
Martin,
Indeed, I see an undocumented operation called Void ShowBrowser(string TabName, string URL)
I've never used it, but I think the names of the parameters make it obvious on how to use it.
philchudley
« Reply #2 on: August 06, 2013, 07:37:08 pm »
My guess would be that the method Repository,ShowBrowser(string TabName, string URL), would created a Tabbed View (named TabName), load the browser and display the page at URL
What I would try to display the HTML of a notes field is the method
[highlight]Repository.GetFormatFromField(string Format, string Text)[/highlight]
where Format = "HTML" and Text is the notes you are examining
This method is documented in the user guide
Hope this helps
Phil
Models are great!
« Reply #3 on: August 06, 2013, 07:47:20 pm »
Martin
If the method is not documented it does not exist per se. Why do you want to open the internal browser of EA instead of a real one?
Martin Trneny
« Reply #4 on: August 06, 2013, 11:46:41 pm »
Thanks guys,
initially I wanted to use an internal browser but it seems to be much more easy to generate a html file from a note and then open external one.
Just for info - method Repository.ShowDynamicHelp(string Topic) do "almost" the same as I expected from Repository.ShowBrowser - open internal web browser.
So I'm suprised why the method ShowBrowser doesn't work.
So there is a workaround how to open an internal browser but you cannot pass your url, a little useless ;D
Martin
Aaron B
« Reply #5 on: August 07, 2013, 09:35:39 am »
Repository.ShowBrowser is undocumented because it was never fully implemented.  The method is exposed, but does not do currently anything.  It's possible that it could be implemented at a later date, but I'm not aware of any plans to do so at this time.
« Last Edit: August 07, 2013, 09:36:12 am by AaronB »
