Author Topic: Creating a Script Fragment Not Working for me  (Read 2562 times)
aniforatos
« on: April 23, 2024, 09:03:42 pm »
I have been trying to follow an example from this site: https://sparxsystems.com/enterprise_architect_user_guide/16.1/model_publishing/custom_script_fragments.html
I have been able to run my script through the scripting window but it does not generate anything when I incorporate it into a document template.
I copy and pasted the code from here: https://sparxsystems.com/enterprise_architect_user_guide/16.1/model_publishing/example_rtf_template_fragment_.html
And my document fragment custom query (I chose the scripting option) looks like this:
MyRtfData(#DIAGRAMID#);
My fragment then looks like this:
custom>
{DateGen}
<custom
Again, running this manually works just fine but it generates nothing when I go to add it as a fragment within my document template.
Please let me know if you need any additional information!
Re: Creating a Script Fragment Not Working for me
« Reply #1 on: April 23, 2024, 09:46:50 pm »
And did you select your script in your template?
Otherwise the first thing to figure out is whether or not your script is actually executed.
Add some logging to a file or something similar (outside of EA's control, so no Session.output) to make sure the script has actually been executed.
aniforatos
« Reply #2 on: April 23, 2024, 11:31:41 pm »
Thanks for the response! I did select the script in the template. I can add some logging. I will report back.
