Author Topic: Section break - problem removing  (Read 10887 times)
Thomas Arnbjerg
« on: May 01, 2024, 11:21:41 pm »
I have a section break in a report template, which can't be removed.
I can insert and remove new section breaks but for some reason this one is can't be touched. Any suggestions?
Re: Section break - problem removing
« Reply #1 on: May 02, 2024, 05:04:30 am »
Sometimes these templates get broken.
The only way I know to resolve this is to start a new one, and copy the content you need (without the broken part) to the new template.
Sunshine
  • Its the results that count
« Reply #2 on: May 02, 2024, 02:39:05 pm »
You could try exporting to MS Word, editing in MS word and re-import.
Happy to help
Thomas Arnbjerg
« Reply #3 on: May 02, 2024, 05:07:12 pm »
The 'Export->Fix in Word->Import' did the trick:
1) Export to Word using 'Edit->File->Save As (Export to File)'
2) Fix the break in Word.
3) Clear the template in EA using 'Edit->File->New (Clear Document)'
4) Import to EA using 'Edit->File->Import File'
shimon
« Reply #4 on: May 06, 2024, 03:34:24 pm »
That's great news. I always thought that these things just get broken sometimes.
