Author Topic: Why won't allocateFrom compartments display?  (Read 2863 times)
mse
« on: May 07, 2024, 02:11:34 am »
I am drawing the allocateTo and allocateFrom between two blocks on a BDD and for some reason I cannot see the option for showing the comparment allocatedFrom in the compartment visibility dialog box. I got it to show up once by creating a new BDD, but only on one of the elements (the allocatedTo part), but I could not show the allocatedFrom compartment.
mse
Re: Why won't allocateFrom compartments display?
« Reply #1 on: May 07, 2024, 02:27:48 am »
Nevermind, my answer was found here:
An allocation won't be listed in a compartment if its connector is shown on the diagram because it's redundant information, so remove either the block or action from the diagram and try again (save, reload, select, Ctrl+Shift+Y).
Source: https://sparxsystems.com/forums/smf/index.php/topic,43082.msg259518.html#msg259518
