Author Topic: Applying Glossary terms to a subset of the Model  (Read 4203 times)
aniforatos
« on: May 14, 2024, 01:46:38 am »
Hello All,
I have a question surrounding glossaries, and I really feel like I cant be the only one to desire this:
I am utilizing the model based glossary. I am creating Glossary entries for some definitions that I want to apply specific packages (not the entire model).
Example, I have a term called "Permission", I dont want to have the definition of "Permission" show up in a note, block, requirement, etc. in Package A but I DO want it to appear in Package B.
Right now, "permission" gets underlined and highlighted with my unique definition whenever I write it in the model.
Thanks in advance!!
« Last Edit: May 14, 2024, 08:38:33 am by aniforatos »
Modesto Vega
Re: Applying Glossary terms to a subset of the Model
« Reply #1 on: May 14, 2024, 05:34:52 pm »
You may be able to achieve the desired result by using the functionality described in https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_fundamentals/glossary_package_struct.html. It is new to the latest version of Sparx EA but I have never tried it.
With the previous glossary functionality, what you describe in the OP was not possible.
« Reply #2 on: May 14, 2024, 06:50:26 pm »
No, glossary entries are "global".
There is no way to limit them to a certain branch of the model.
You could send in a feature request, but I'm not sure if this would get much traction.
aniforatos
« Reply #3 on: May 14, 2024, 11:49:42 pm »
Sad news, but thank you for letting me know!
Modesto Vega
« Reply #4 on: May 15, 2024, 12:25:50 am »
Thank you Geert, somehow I am not too surprised.
This takes us back to a conversation that we have had several times in this forum: how Sparx EA implements or does not implement the concept of "model"?
Glossaries should be model specific not repository specific, Sparx EA does not really have a concept of "model" as separate from a package or a repository.
« Reply #5 on: May 15, 2024, 02:46:23 am »
They probably respond: make model==repository.
Modesto Vega
« Reply #6 on: May 15, 2024, 03:34:38 am »
Thank you qwerty, you are most likely correct. Strictly speaking that means that an Enterprise Model is a repository, and a model for each application in the enterprise model (both "As Is" and "To Be") will need a dedicated repository. I am not sure if this is very elegant or manageable (think dependencies). I know Sparx EA is flexible enough not to currently require using this approach.
