Author Topic: EA 17 Beta install removed my EA 16  (Read 16438 times)
wivel
  • Driven by Models
« on: June 06, 2024, 04:30:46 am »
Hi
Tried to install EA 17 Beta on a different folder, as I have done before when having multiple versions installed, but it still removed my EA 16 installation.
What did I do wrong?
Henrik
Re: EA 17 Beta install removed my EA 16
« Reply #1 on: June 06, 2024, 05:54:44 am »
I usually rename my old EA folders beforehand. But when installing the beta specifying the target folder to be EA17 this worked as well.
« Last Edit: June 08, 2024, 08:16:21 am by qwerty »
« Reply #2 on: June 06, 2024, 08:40:15 am »
For as long as I can remember, EA has used the same upgrade code for the installer. Which means it always has removed the previous versions during install.
ea0522
« Reply #3 on: June 06, 2024, 03:36:44 pm »
Maybe it has to do with 32 vs 64 bit versions?
When I isntalled V16 64, V15 32 was not removed.
wivel
  • Driven by Models
« Reply #4 on: June 07, 2024, 04:41:04 am »
Seem to recall it is possible to have multiple installations if you install in different folders.
Will do some more investigation.
Henrik
PDC
  • Systems Engineer
« Reply #5 on: June 07, 2024, 05:40:39 pm »
Henrik
Yes.
I have 15.2 in [C:\Program Files (x86)] and 16.1 in [C:\ProgramFiles].
Phil
« Reply #6 on: June 07, 2024, 05:44:19 pm »
Henrik
I've always first renamed the EA folder, and then installed the new version at the standard location.
wivel
  • Driven by Models
« Reply #7 on: June 07, 2024, 11:14:40 pm »
I did it ‘the other way round’. Kept the EA 16 folder name and changed the install folder name when installing EA 17.
Will try to rename the existing EA 16 folder before trying again.
Henrik
wivel
  • Driven by Models
« Reply #8 on: June 08, 2024, 06:36:31 am »
Henrik
That did the trick.
Thanks Geert
