Author Topic: Instance Diagram from Block Diagram  (Read 3049 times)
SpencerSkelly
« on: June 12, 2024, 01:09:36 am »
Hello all,
First, thanks for any guidance in advance, this forum has been really helpful.
I have a number of variants of an assembly.
I have a block diagram of a generic version.
Each assembly uses different part numbers (modeled as instance on generic block)
These assemblies are considered a module, built from assemblies, that are built from components (ends up being a dozen BDD and IBD to define the whole)
I'd like to copy the block diagrams and be able to use the IBDs as well, but generate all instances.
They all follow the same BDD/IBD definition, but some of these end up with requirements that are not common across all assemblies, so I'd like to be able to bring full definition to each variant.
I would like to be able to go in and define all part names and values without doing this manually, especially the IBDs...
These components are not always compatible, so I can't just replace one part for a variant, for example
Any advice or a tutorial on how to do this without manually recreating every variant?
