Author Topic: Saving a diagram to be viewed as a Relationship Matrix  (Read 8021 times)
Modesto Vega
« on: June 18, 2024, 11:06:11 pm »
In a previous version of Sparx EA, before 16.1.1628 I somehow managed to save a diagram to open by default as a Relationship Matrix. Unfortunately I did not make a note of how I did this and can no longer replicate it.
Any help will be greatly appreciated.
Re: Saving a diagram to be viewed as a Relationship Matrix
« Reply #1 on: June 18, 2024, 11:18:51 pm »
Open the properties, and check for Diagram | Mode
Modesto Vega
« Reply #2 on: June 19, 2024, 02:51:56 am »
Thank you Geert, I thought you were going to say that. Perhaps my eyes are getting too old, where about is "mode"? I cannot find it in version 16.1.1628.
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: June 19, 2024, 09:56:36 am »
The 'Mode' is in the properties dialog of a diagram. So double-click the background of a diagram, then select 'Diagram' group and we can find the 'Mode' panel at the upper-right of the dialog. In the Mode panel, there are 4 checkboxes and one of them is the 'Always Open as Relationship Matrix'.
t-kouno
Modesto Vega
« Reply #4 on: June 19, 2024, 06:51:44 pm »
Thank you Takeshi, found it. The option reads "Always Open as Relationship M..." - i.e., an incomplete sentence - instead of "always Open as Matrix" which most likely what I was expecting.
Sparx EA could make some usability improvements.
Takeshi K
« Reply #5 on: June 20, 2024, 10:26:36 am »
You might change Windows DPI and/or fonts to draw dialogs. About the DPI, usually Windows manages Textboxes to expand their width so the whole texts are displayed, but I know in some cases (especially, non-English Windows and default Windows screen font is different), Windows cannot display whole text in the width and then displays them with '...'.
In this case I am on the Dev side, it is very very difficult to avoid this '...' behaviour on Windows for all cases and all conditions. I hope it never happens when the DPI is 100% and the font is not changed from the original English fonts (Segoe UI maybe).
t-kouno
Modesto Vega
« Reply #6 on: June 20, 2024, 06:24:18 pm »
Thank you Takeshi. If this was happening on a smaller screen, I will totally agree with you. But it is happening on a 1920 x 1080 screen, where the Diagram properties dialog occupies less than 1/4 of the screen. These dialogues should be resizable or, at least, size themselves to occupy more screen real state.
« Reply #7 on: June 20, 2024, 06:33:17 pm »
I don't think it's the size of the screen that matters, but the zoom or the default system font size you have configured.
If you use 100% I'm pretty sure it works just fine.
I still have a lot of room left on that dialog after the "Always Open as Relationship Matrix" regardless of the size of screen om using it on.
Modesto Vega
« Reply #8 on: June 20, 2024, 11:48:47 pm »
A question before I make another contribution, are you referring to OS Display settings, specifically the Scale and layout or Sparx EA settings?
« Reply #9 on: June 21, 2024, 12:17:09 am »
OS Display settings, specifically the Scale and layout.
Unless there is an option to change the system font and size in EA as well?
Modesto Vega
« Reply #10 on: June 21, 2024, 02:16:00 am »
Thank you Geert, both displays are set to 100%, I will check tomorrow when I will be using a different display. With the setup I am using today, there is no room left in any of the dialogs.
« Reply #11 on: June 21, 2024, 02:44:28 pm »
Weird. Here's how the dialog looks on my computer:
https://imgur.com/a/r3lwNdI
